Car shaking after new tires
220,000 MILES • 3.3L • 6 CYL • 4WD • AUTOMATIC
BWPEINHARDT
I had two new front tires installed on vehicle at WalMart.
After installation, front end of car began shaking and pressure light came on when reaching speeds of 50+ MPH. This had never happened before the new tires were installed. I checked the pressure gauge on all 4 tires; all 4 were fine.
I took the car back to WalMart where they double checked their work, checked the balance on all 4 tires, and checked their thread work on the lug nuts. They said everything was fine.
Car still shakes at higher speeds. Sometimes it increases when decelerating.
Any thoughts on what the problem could be?
Thank you for your time.
Jun 1, 2021 at 5:57 PM
Good morning,
This sounds like a shifted belt in one of the new tires.
Take it back and have them install 2 new tires under warranty. Even with a shifted belt, it can balance on the machine but fail under load.
Also, it sounds like they damaged one of the sensors for tire pressure. Have them replace them as well. It is their responsibility not to damage the sensors.
Jun 1, 2021 at 6:51 PM
