Car shaking and check engine light is on
172,000 MILES • 3.8L • 6 CYL • AUTOMATIC
LAKIESH
When I press the gas is not moving like it should and I can smell gas inside . And my check engine light is on.
Apr 11, 2020 at 6:07 AM
Okay. This sounds like a misfire. However, the check engine light being on is a good thing. We need to check for what the codes are and that can help us figure out what the issue is.
If you cannot pull codes then I would suggest stopping by a parts store as most will pull them free of charge.
As I said, I think this is a misfire but the codes will tell us which cylinder or if it is another issue.
Let me know what the actual codes are and we can go from there. Thanks
Apr 11, 2020 at 9:07 AM
  • 55,746 POSTS
Here is a how you can get he codes:
Apr 11, 2020 at 1:10 PM
