When braking the front end shakes
100,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
FRANKSNYDER
High speed or low speed when I brake my front end shakes pretty good. I changed the rotors and brake pads and the caliper on the right hand side of past year. I did both rotors with brake pads still shaking not as bad but still shaking.
Jul 5, 2020 at 3:55 AM
Good afternoon,
When you changed the rotors, did you clean off the mounting surface on the hub?
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
When you were done the job, did you hand torque the wheels?
All this makes a difference with the rotors causing the vibration.
Also, the rotors, if you got the cheap ones, a lot of times they are warped out of the box. Parts houses sometimes do not stack them correctly and if they sit on a concrete floor, they will warp without even being sold.
Jul 5, 2020 at 4:56 AM
