Car Shaking
136,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
MICHAEL LABARBERA
  • 5 POSTS
My car shakes at only at speeds of fifty to sixty mph. It does not shake at speeds below fifty mph and it does not shake at speeds above sixty mph. What is the most likely cause?
Nov 16, 2016 at 7:01 PM
  • 31,937 POSTS
Check for out of round tires or tires with a deformity, start here.
Nov 16, 2016 at 7:49 PM
JIS001
  • 3,412 POSTS
Just to add to it, if the vibration is while under load (accelerating) at those speeds then your axles are bad. If your tires are faulty, check your suspension. The lower control arm bushings do not last very long on those vehicles.
Nov 17, 2016 at 2:35 AM
