car shaking
187,900 MILES • 6 CYL • FWD • AUTOMATIC
TINA HARRIS
I the changed the plugs, wires, and coil pack. I checked engine light flashing on and off. Reading a PO300 code, Random misfire code?
May 17, 2016 at 2:40 AM
JOHNNYT73
  • 924 POSTS
okay. Was it doing the misfiring before you changed the parts?
May 17, 2016 at 3:03 AM
TINA HARRIS
No, it was running fine. Then one morning it heard a squeaking sound and it started to shake and the check engine light started flashing.
May 17, 2016 at 5:50 AM
TINA HARRIS
I am sorry, yes it was misfiring before we changed the parts.
May 17, 2016 at 5:51 AM
  • 55,709 POSTS
Hi Tina,
Does it misfire under power if so, then I would check the compression to see if all cylinders are okay it could be an injector,
here are two links that can help you
and
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
let me know what you find
Best, Ken
May 21, 2016 at 6:10 AM
