Car shakes while Idling, Check engine light blinking, Smells bad
200,000 MILES • 6 CYL • FWD • AUTOMATIC
CMORRILL
Car shakes while idling and the check engine light and TCS are flashing. Has a smell that is coming out when on, and has a pull when sitting
Apr 23, 2015 at 3:30 PM
  • 55,759 POSTS
It sounds like you have an ignition coil that is not working or you have a fouled spark plug. Lets start by reading the codes to see what come up.
Here is a guide to check the ignition coils as well.
Cheers, Ken
Feb 8, 2018 at 4:13 AM
DEELAD
  • 0 POST
I did what you said but it is not helping? I looks through the guiders and the coils seem to be working okay but one plug is black? #3 cylinder?
Feb 8, 2018 at 4:14 AM
  • 55,759 POSTS
This is because the cylinder probably has low compression due to a burnt valve. Please follow this guide to confirm the issue.
Feb 8, 2018 at 4:17 AM
DEELAD
  • 0 POST
Yep it has low compression time for a valve job,, bummer, thanks for your help.
Feb 8, 2018 at 4:18 AM
