My car jerks and hesitates for a couple seconds when i put my foot on the gas to accelerate during low speeds. As soon as I step on the gas after a stop it's when you feel the engine hesitate like it's resisting for seconds then it's fine.
Spark plugs are not that old, it doesn't even have five thousand miles on them yet.
Air filter could be slightly dirty but not clogged to the extent the car doesn't accelerate smoothly.
Mass air flow sensor was checked, and I cleaned
Throttle position sensor was replaced
Coolant temperature sensor was replaced
Fuel filter on this car isn't serviceable until the fuel pump is replaced and i am getting fine fuel pressure.
Coil packs would be an issue if the car were misfiring badly or code set.
I am thinking a bad ignition module or dirty fuel injectors. Do you recommend using a fuel additive to clean the fuel injectors? Or can I check the ignition module? Where can it be located on this vehicle? Is it hard to get too to check with a multimeter?
May 3, 2022 at 4:45 AM
