I have a 97 cavalier, 2.24cyl. 2wd. It has approx 151,000 on it. I replaced the water pump due to it was leaking. Afterwards the car seemed to bog down. I replaced the pugs and wires and that seemed to be a temp. solution. Driving home a few days ago, i heard a "pop" then a scraping sound. I pulled over to check to see if it was maybe my exhaust. It wasnt. Now whenever I go up a hill, I gradulaly lose speed and momentum. Flat surfaces fine. downhill, fine. Its only when going uphill. It seems like the transmission is shifting harder as well. Any help or suggestions?
Jun 10, 2013 at 4:23 AM
