When attempting to pull it out of driveway seems like car wants to stall
1997 JAGUAR XJ6
133,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
LISA JOY RILEY
  • 16 POSTS
I was told i still need to get a "harmonic balancer' (crankshaft pulley) welded onto the car, when i took it to the shop.
I got an oil leak fixed, so i put this other repair off at the time. Now i am wondering if this almost stalling behavior has anything to do with what i delayed fixing?
Or is it low on gas, needs a tune-up, or what?
Dec 30, 2018 at 11:57 AM
  • 110,244 POSTS
Wow, I can't think of any reason to weld a harmonic balancer on to the crankshaft. It is bolted on and balanced. Welding it would not be a good idea in my mind.
As far as the driveability issue, does it only happen when first started?
Any of the things you mentioned, low fuel, low fuel pressure, tune up, vacuum leak, bad idle air control valve, dirty throttle body, can cause this.
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
https://www.2carpros.com/articles/how-to-replace-an-idle-speed-control-motor-iac
Let me know if it is only once a day, when you first pull out, or if it happens all the time. Also, is there anything associated with it?
I hope something I added is helpful.
Take care and have a nice New Year,
Dec 30, 2018 at 2:37 PM
