Car runs then shuts off?
150,000 MILES • 3.0L • 6 CYL • TURBO • 2WD • MANUAL
JJWWIILL
I recently had my engine pulled out, I had to drop the pan to look for belt and I also swapped the head over because of a rounded injector bore. Now when I start the car it runs for a little the dies no matter how much gas I give it. If I unplug the crank sensor it will long crank but start and run pretty good.
Sep 29, 2025 at 12:12 AM
BLACKOP555
  • 10,386 POSTS
Any codes? Make sure its timed right. I would verify timing and vacuum leaks first.
Sep 29, 2025 at 10:57 AM
  • 55,649 POSTS
We need to run the codes to see which ones are stored to help us fix the problem, here is a guide to help us get started:
Please upload pictures or videos in your response, it will help us see what is wrong.
Sep 30, 2025 at 3:02 AM
