Car rolls in park
130,000 MILES • 4 CYL • 4WD • AUTOMATIC
JASONKOZ
  • 5 POSTS
The other night I ran over a tree trunk pretty hard on the road. It knocked out my alignment so I had the alignment done and tires balanced. I had it done at a tire shop and when I got my car back I got in and realized my car was rolling in park mode. I also realized that my shifter was a lot easier to move too. All the gears work except park. Side note: this is a hybrid vehicle.
Mar 3, 2019 at 3:48 AM
Good afternoon,
Chances are you have damaged the shifter cable. That is what controls it going into park.
You may have done more damage than you thought.
I would have this checked at a shop to check the exact issue.
Mar 3, 2019 at 4:11 AM
JASONKOZ
  • 5 POSTS
The problem I am having is that I cannot find the shifter cable on the transmission and am starting to believe there isn’t one since it’s a hybrid and has a ECvt transmission.
Mar 3, 2019 at 5:44 AM
Okay, there is a shift cable from the shifter out to the transmission. I attached a picture for you.
Mar 3, 2019 at 5:52 AM
JASONKOZ
  • 5 POSTS
Thank you! But where can I access that on my car?
Mar 3, 2019 at 7:12 AM
You need to remove the console and the shifter to access the cable. The other end goes to the transmission. You may need to go under the car and look at the cable where it comes out of the body and follow it to the transmission.
Mar 3, 2019 at 7:24 AM
JASONKOZ
  • 5 POSTS
I have a hybrid and my car has been rolling in park. I cannot find the gear selector cable connection to the transmission to check the connection. Can you please help me locate the connection to the transmission?
Mar 11, 2019 at 9:40 AM (Merged)
Good afternoon,
I found a recall on this issue for you to review.
Change Vehicle Bookmarks Library Request Conversion Calculator Technician's Reference - Collision
Search vehicle information
Community 8 Create Quote
2008 Ford Truck Escape 4WD L4-2.3L VIN H Hybrid
Recall 15V606000 - Rebuilt Shift Lever May Disengage
Vehicle Transmission and Drivetrain Automatic Transmission/Transaxle Shifter A/T Technical Service Bulletins Recall 15V606000 - Rebuilt Shift Lever May Disengage
RECALL 15V606000 - REBUILT SHIFT LEVER MAY DISENGAGE
Report Receipt Date:
SEP 29, 2015
NHTSA Campaign Number:
15V606000
Component(s):
POWER TRAIN
Potential Number of Units Affected:
57
Manufacturer:Ford Motor Company
SUMMARY:
Ford Motor Company (Ford) is recalling certain model year 2001-2008 Ford Escape and Mercury Mariner vehicles manufactured March 31, 2001, to September 1, 2009. The affected vehicles are equipped with either a 2.3L or 3.0L engine and have had their CD4E transmission replaced with a rebuilt one. These service repair part transmissions have a shift lever bolt that may not be properly tightened. As a result, the shift control lever could disengage from the transmission without warning.
CONSEQUENCE:
If the shift lever disengages from the transmission, a driver may be unable to shift gear positions and the indicated shift position may not represent the gear position the vehicle is in. Should a disengagement occur while the vehicle is being driven, when the driver goes to stop and park the vehicle, the gear selection indicator may show that the transmission is in the "PARK" position, but the vehicle transmission may not actually be in the "PARK" gear position. If the vehicle is not in the "PARK" position there is a risk the vehicle will roll away as the driver and other occupants exit the vehicle or anytime thereafter. A vehicle rollaway increases the risk of injury to exiting occupants and bystanders.
REMEDY:
Ford will notify owners, and dealers will inspect the transmissions and either tighten the manual shift lever bolt or replace the manual shift lever assembly. These repairs will be performed free of charge. The recall is expected to begin October 19, 2015. Owners may contact Ford customer service at 1-866-436-7332. Ford's
number for this recall is 15S28.
NOTES:
Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888- 327-4236 (TTY 1-800-424-9153), or go to www.safercar.go.
JASONKOZ
  • 5 POSTS
I went to a Ford dealership and they searched my VIN number. They did not find any recalls.
Mar 11, 2019 at 10:50 AM
I would have them check it anyway.
Mar 11, 2019 at 10:54 AM
