Engine reviving high when transmission is in park
200,000 MILES • 1.5L • 4 CYL • AUTOMATIC
NESSA WALKER
Engine revs up high when transmission is in park. And when I add gas, it has trouble starting up.
Mar 10, 2022 at 6:57 AM
SQM
  • 6,383 POSTS
So, how high does it idle, when in park? What about when you put it in drive?
Does it run rough as you drive?
This could be an issue with the throttle actuator. Is your check engine light illuminated?
If so scanning and retrieving the code(s) can help with the diagnostics.
Here is a guide on how to retrieve engine error codes:
Let me know little more details of what you have been experiencing.
Mar 10, 2022 at 10:18 AM
NESSA WALKER
The RPMs go up between 2 and 3, it goes up and down repeatedly when in park and when I reverse it idles high too. But when I’m driving it’s fine, no problem there. The other issue is when I put gas in, it has trouble trying to start, every time when I put in gas… also yes, the check engine light is on. I had the throttle cleaned but no fix to the problem.
Mar 12, 2022 at 1:49 AM
SQM
  • 6,383 POSTS
I think a good first step would be to scan and retrieve the code(s) for the check engine light. This issue could be due to a faulty within the throttle actuator and it is not providing proper signal to the ECM.
You can take it to your local auto parts store, and they can scan the engine light for you.
Let me know what code that you find.
Mar 12, 2022 at 5:22 AM
NESSA WALKER
Okay, I’ll do that. Thank you
Mar 12, 2022 at 5:38 AM
SQM
  • 6,383 POSTS
You are welcome.
Mar 12, 2022 at 6:43 AM
