Emissions light is on and blinking i jus did a complete tune up?
205,000 MILES • 3.6L • AUTOMATIC
JOSH HUFF
my van emission light is on and blinking i jus did a complete tune up. new injectors ,plugs, coils, gasket. new crankshaft position sensor and camshaft position sensor on bank 2.. fixed the problem i was having stalling out so it ran okay ,, i drove around for a day now broke down again with flashing emission light ... getting codes saying misfire cylinder 3 and multiple misfire , lost communications/w com and poor voltage .... tested my alternator and is fine ... dont know why im getting misfire when i jus replaced with all new parts ... thinkink im having a faulty o2 sensor but no codes pop up for that ... any suggestions and help to figuring out the issue
Aug 31, 2026 at 2:57 PM
  • 55,694 POSTS
Yep, we can help you but I need to know the code numbers. Also, it sounds like you are having issues with the cylinder #3 I would remove the spark plug to make sure it did not get cranked during installation which is common. This can cause the random misfire codes as well. Here is a guide that can help.
https://2carpros.com/articles/engine-misfires-or-runs-rough/
Sep 1, 2026 at 5:18 PM
