Car shuts off while driving
112,500 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
CHARLES DANBERRY
Driving along at regular speed and car quits. Battery, alternator and fuses replaced.
Feb 3, 2018 at 1:16 AM
  • 55,694 POSTS
Do you have a check engine light on?
Cheers, Ken
Feb 4, 2018 at 4:34 AM
CHARLES DANBERRY
No.
Feb 4, 2018 at 12:19 PM
  • 55,694 POSTS
This sounds like a crankshaft angle sensor is going out, but to be sure when the engine stalls we need to check for spark. here is a guide:
If there is no spark I would replace the sensor here is a guide to show you what you are in for when doing the job. When the crankshaft sensor goes out most of the time it will not set a code.
The crankshaft sensor is located at the rear of the engine lower left near the transmission flange.
Cheers, Ken
Feb 5, 2018 at 1:39 AM
