Car pulls to the left, alignment says it is caster
2014 MITSUBISHI LANCER
35,000 MILES • 2.0L • 4 CYL • TURBO • 4WD • AUTOMATIC
STAN164
I have a 2014 Lancer Ralliart. My left front caster is off by one degree (1.5) the alignment place that checked my alignment said to replace the strut and that will fix it. I read online that it is a control arm or a control arm ball joint that is the issue. Would any of these make my caster off by a whole degree?
The car only pulls to the left when accelerating. Otherwise it goes fairly straight.
Oct 14, 2018 at 8:18 PM
Good morning.
It sounds like they are guessing. It could be either that can cause the caster to be out. It is a non adjustable angle.
Somebody needs to check the actual failed part. Something happened on that side to put it out of alignment. Did you have an accident or hit a big pothole?
I would not rely on the internet as it is most of the time inaccurate. You need a qualified tech to give you the exact issue.
As far as pulling on acceleration, have them check the axle shafts. Bad inner CV joints will cause this issue.
https://www.2carpros.com/articles/upper-control-arm-replacement
https://www.2carpros.com/articles/symptoms-of-a-bad-cv-axle-joint
Oct 14, 2018 at 8:25 PM
