Did you have any warnings about the charging system?
It sounds like you have an engine failure internally.
Will it start up again?
Apr 16, 2020 at 10:54 PM
AURIA BROWN
MEMBER
I'm going to see if i can get it to start up today with a jump.. When driving in the car i just heard the slapping noise on the right side at the front of the car not sure if it was the motor or not exactly.
Apr 17, 2020 at 3:16 AM
✓Experienced Mechanic
Okay, I would also check to see if you can turn the engine by hand prior to jumping it.
Apr 17, 2020 at 3:31 AM
AURIA BROWN
MEMBER
How exactly would i do that? i have no clue where that is.
Apr 17, 2020 at 5:11 AM
AURIA BROWN
MEMBER
What would i use to do it?
Maybe you could have someone help you when you go to the car.
They could grab the fan belt and try to move it so the engine will rotate.
