I am replacing my clutch and I don’t know which one is good?
200,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
ANTONIO LOPEZ2
I am replacing my clutch and I don’t know which one is good . It’s a daily driver and I also drive fast. Can you give me diagrams on the job?
Dec 19, 2020 at 3:26 PM
I will attach the info from the manual also here are a couple guides that will help with replacing the clutch as these have good info that the manual does not include:
https://www.2carpros.com/articles/how-to-replace-a-clutch
https://www.2carpros.com/articles/throw-out-bearing-replacement
Below you will find the process from the manual that will provide the specific info needed.
As for which part to go with, I would stick with the OEM kit just because this is a wear item that is not the easiest to replace so I would not want to put a cheap part in because if there is an issue, you have to redo the whole process.
Please run through this and let us know what questions you have.
Dec 3, 2021 at 6:23 AM
