How to increase the engine power?
104,600 MILES
AARONN
  • 125 POSTS
How to have my car get more power easily and the cheapest possible way(s)?
Jul 8, 2024 at 4:56 AM
CANNON1349
  • 861 POSTS
We have a great guide regarding experiencing low power:
https://www.2carpros.com/articles/engine-has-low-power-output
At your mileage I would check, clean, or replace the following things:
1) Engine air filter
https://www.2carpros.com/articles/how-to-replace-a-car-air-filter
2) Carbon build-up at throttle body
3) Replace spark plugs
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
https://www.2carpros.com/articles/how-to-change-spark-plugs
4) Fuel system cleaning/injector cleaner
If you have any DTCs in the computer, we will need to take care of that first to help the car. Let us know what you decide to do, and if we can help!
Thanks,
William
Jul 8, 2024 at 9:31 AM
AARONN
  • 125 POSTS
Are high performance spark plugs worth it?
Jul 9, 2024 at 1:33 AM
CANNON1349
  • 861 POSTS
It depends on what you mean by "high performance". Most Asian manufacturers use iridium plugs, which are considered high performance. For your Toyota that would be fine. However, I would not trust a spark plug that deviates from the OE recommended gap, this raises the possibility of having issues due to the amount of computer intelligence of cars nowadays. I always stick with the OE specified gap and spark plug type.
William
Jul 9, 2024 at 9:56 AM
AARONN
  • 125 POSTS
Like a NGK Platinum spark plug?
Jul 9, 2024 at 10:02 AM
CANNON1349
  • 861 POSTS
NGK is a good brand, but if you can get and afford it, I would find Denso double platinum or iridium spark plugs. Denso is the OE manufacturer of these plugs.
Thanks,
William
Jul 9, 2024 at 10:04 AM
