Car performing bad and noisy
45,200 MILES • 1.6L • 4 CYL • FWD • MANUAL
STEVIE19732017
I had it serviced and just gone through its MOT with no problems. Car very lumpy when in idle, when driving very jerky hardly any power and engine management light come and flashes also traction control light. I have got a code reader diagnostic machine plugged it in and it came up with code P0304. which states cylinder four misfire detected. took coil pack off and noticed the forth rubber was all split. checked spark plugs which did not look too bad so I changed coil pack and the code no longer shows. but, still shocking when running. Any idea what this could be? Please.Thanks.
Dec 21, 2016 at 3:12 PM
  • 55,770 POSTS
Hey STEVIE,
Even though the mileage is low on the engine I would start with the spark plugs and do a vacuum leak test. here are a couple of guides that will help you fix the problem.
https://www.2carpros.com/articles/how-to-change-spark-plugs
and
Please let us know happens so it will help others.
Best, Ken
Dec 26, 2016 at 11:04 AM
