CAR OVERHEATING PROBLEM FOR A 1995 CORVETTE!!! HELP! PLEASE
60,000 MILES • 5.5L • V8 • RWD • AUTOMATIC
DANDELUXE
When running w/ the air off, neither fans run, causing the motor to overheat. with the air
on, both fans run, and the temp is normal. fuses is good, i have taken the car to 2
places, neither can find the problem. 1 place says he is studying the schematics, but no
luck. i know the car has 2 temp sending units, could one of these be bad? weather is
so f--king bad the i am not planing to move the car till spring(if you live close to chicago
you will know what i mean)!! can anyone help, has anyone had this problem before?
thanks
Jan 7, 2014 at 3:13 AM
SATURNTECH9
  • 30,869 POSTS
Sounds like a bad coolant temp sensor that one has a black wire and yellow wire going to it.
Jan 7, 2014 at 3:49 AM
DANDELUXE
Thank you very much for the information, I will google this part to see if I can find the location of it on the engine. again thank you, Dan
Jan 8, 2014 at 5:48 AM
SATURNTECH9
  • 30,869 POSTS
Your welcome if the fans come on with the ac you know the fan motors and relays work only thing really left is the coolant temp sensor.
Jan 8, 2014 at 5:52 AM
SATURNTECH9
  • 30,869 POSTS
I see the coolant temp sensor is on lower front of engine.
Jan 8, 2014 at 6:41 AM
