When running w/ the air off, neither fans run, causing the motor to overheat. with the air
on, both fans run, and the temp is normal. fuses is good, i have taken the car to 2
places, neither can find the problem. 1 place says he is studying the schematics, but no
luck. i know the car has 2 temp sending units, could one of these be bad? weather is
so f--king bad the i am not planing to move the car till spring(if you live close to chicago
you will know what i mean)!! can anyone help, has anyone had this problem before?
thanks
thanks
Jan 7, 2014 at 3:13 AM
