Car overheating fan
178,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
ROG1993
So I don't know if it's the fan thermostat radiator or the relay but I put a new fuse in for the fans but my car overheats after being on for a seven to ten minutes and the temperature gauge rises fast. I've put water in the radiator reservoir to see if anything may leak and it let all the water out. but I believe it's from the fans not cutting on but they cut on when the car is off. I'm kind of lost about the whole situation first Honda I've had. i need to figure out the problem so I can fix it as fast as I can.
Feb 9, 2019 at 12:43 AM
SCGRANTURISMO
  • 4,897 POSTS
It sounds to me like you could have a coolant leak somewhere. I am including a few links below for you to go through. Please get back to me with what you find out and we can help you from there.
https://www.2carpros.com/articles/engine-cooling-system
https://www.2carpros.com/articles/symptoms-of-a-bad-water-pump
https://www.2carpros.com/articles/radiator-pressure-test
Thanks,
Alex
2CarPros
Feb 9, 2019 at 11:11 AM
