Car overheating and A/C not cooling the car when car is parked
180,000 MILES • AUTOMATIC
BROOKELYNGOMEZ
  • 5 POSTS
Whenever the car is in park or still for too long the temperature gauge starts moving up and the A/C no longer feels cool but starts blowing out warm air. Now that it’s getting hotter out the car is overheating when in park. what should I do?
Jun 9, 2021 at 5:53 AM
Good afternoon,
You need to perform a pressure test to check for any coolant leaks. That will cause overheating. Check for any leaks at the hoses.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
https://www.2carpros.com/articles/radiator-pressure-test
If that is good, I would suggest a thermostat as it may be stuck closed or partially closed.
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Are the cooling fans working when it heats up? If they are not, then that is the reason it is heating up at idle.I attached a wiring diagram of the fans for you. I would check the fuses to be sure there is power on both sides of the fuse.
https://www.2carpros.com/articles/how-an-electric-cooling-fan-works
Jun 9, 2021 at 7:30 AM
