Car overheating
232,485 MILES • 1.6L • 4 CYL • 4WD • AUTOMATIC
CARCOUCH
Hello , same little red Nissan as before here. I am having overheating problems. I recently got the car back from the shop after they replaced the fuel pump and hooked up a switch to turn the fuel pump on manually instead of me looking for another computer. On the way home I noticed the needle was going up. Not very very fast but it still was overheating. I looked in the coolant reservoir tank it was overfilled. It looks like it is pushing the coolant out or it is being backed up into the coolant jug. Next day I drove it without the AC and it was doing fine, but after two hours it eventually started overheating again. I turned on the heat while I was driving to see what effect that would have and it surprisingly cooled the temperature down. The car's radiator is full of coolant and once the coolant jug went back down it is now at its normal place below the line. Any suggestions before I go spend more money?
Aug 30, 2018 at 3:23 AM
CJ MEDEVAC
  • 11,000 POSTS
Is this the original radiator?
You might try a flush from the auto parts store, sometimes the crud built up inside the radiator just will not come out, then you might be looking for a new radiator. Nowadays they are aluminum in a plastic shell, many are $120.00 or less.
I change my thermostats once a year just as super preventative maintenance. At present, this not sound like your issue.
With your heat on (heater core, basically a small radiator) this may be compensating for an inefficient radiator.
Insure your cooling fan is working for the radiator. I have no idea what was involved in your fuel pump modification, maybe something they did knocked a connector loose or blew a fuse. It might be that they disabled the fan tying into a wire.
As far as your fuel pump turned on manually, not a good idea! Who is going to turn it off when you have an accident and it is steady feeding a fire!
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Return with good news!
The Medic
Aug 30, 2018 at 9:21 AM
