Overheated due to no coolant, now the battery is not working properly
ZBM1996
  • 2002 FORD EXPLORER
  • 249,000 MILES
Yesterday my car overheated due to no coolant. I had it towed home, added Coolant and it started right up. I went to start the car this morning and there was no power at all. Went to jump the car. As soon as the cables were attached the car ding instantly started then was able to start right up. I thought it was the end, but when I turned it off everything instantly went dead again (no lights, chimes, etc).
Saturday, August 24th, 2019 AT 8:15 PM
JIS001
  • 3,411 POSTS
Hi and welcome to 2CarPros. It appears by your description that your battery has failed. Here is a link on how a battery works battery symptoms, and how to test it:
https://www.2carpros.com/articles/how-a-car-battery-works
https://www.2carpros.com/articles/symptoms-of-a-bad-car-battery
Saturday, August 24th, 2019 AT 9:13 PM
ZBM1996
I had the battery tested and it came back as a good battery.
Saturday, August 24th, 2019 AT 9:33 PM
JIS001
  • 3,411 POSTS
How are the terminals? Are the cables and terminals clean and tight?
Saturday, August 24th, 2019 AT 10:05 PM
ZBM1996
The negative terminal has exposed wires. It should be replaced. They don’t have corrosion.
Saturday, August 24th, 2019 AT 10:10 PM
JIS001
  • 3,411 POSTS
If the wires are exposed and strands are broken then you should replace the cable.
Sunday, August 25th, 2019 AT 1:34 PM
