Car overheats
200,000 MILES • 2WD • MANUAL
GARY BREWER
I have to keep refilling reservoir. Car still gets hot after ten miles or more fan, works fine.
May 12, 2018 at 2:46 AM
Good afternoon.
It sounds like you have a leak in the system. You need to do a pressure test to determine the leak and repair it. Guide below on pressure test.
The thermostat may not be opening causing it to heat up as well.
https://www.2carpros.com/articles/radiator-pressure-test
https://www.2carpros.com/articles/how-an-engine-thermostat-works
May 12, 2018 at 3:37 AM
GARY BREWER
Is it the thermostat or what?
May 13, 2018 at 3:55 AM
