HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Saturn
SL2
Engine
Symptoms
Overheat
SPONSORED LINKS
Car overheats
GARY BREWER
MEMBER
1998 SATURN SL2
2WD
MANUAL
200,000 MILES
I have to keep refilling reservoir. Car still gets hot after ten miles or more fan, works fine.
Saturday, May 12th, 2018 AT 9:46 AM
MECHANIC
Good afternoon.
It sounds like you have a leak in the system. You need to do a pressure test to determine the leak and repair it. Guide below on pressure test.
The thermostat may not be opening causing it to heat up as well.
https://www.2carpros.com/articles/radiator-pressure-test
https://www.2carpros.com/articles/how-an-engine-thermostat-works
SPONSORED LINKS
Saturday, May 12th, 2018 AT 10:37 AM
GARY BREWER
MEMBER
1 POST
Is it the thermostat or what?
Sunday, May 13th, 2018 AT 10:55 AM
Please
login
or
register
to post a reply.
Related Engine Overheat Content
1997 Saturn Sl2 My Car Overheated The Day
Engine Cooling Problem 1997 Saturn Sl2 Two Wheel Drive Automatic 40410 Miles My Car Was Smoking The Other Day And All The Coolant...
Asked by
dennedo
1997
SATURN SL2
VIDEO
Is Your Engine Cool Enough to Check?
Instructional repair video
GUIDE
Overheating Symptoms
An overheating engine is never a good thing to have happen. If the problem is caught quickly you can save the headache of a major engine repair. Knowing the information from...
1994 Saturn Sl2 Engine Hot//transaxle Light
My Satrun Is Showing A Dummy Light That Is Flashing Either Overheating Or Manual Transaxle Is Low On Fluid The Car Is Not Running Hot And...
Asked by
dan hood
1994
SATURN SL2
1995 Saturn Sl2 Can Not Backup When Engine Hot
Please Help, My Saturn 95, In The Morning I Cold Engine I Can Shift Gear To Backup And It Ok, When Run Go To Work About 45 Min. And Park...
Asked by
Dany50
1995
SATURN SL2
1999 Saturn Sl2 99 Sl2 Occasionally Overheating At...
Works Great Majority Of The Time, Car Reaches Temp (about A 1/4 On Coolant Temp Gauge Where Its Been For 10 Years) And Stays There. ...
Asked by
billy9999999
1999
SATURN SL2
1996 Saturn Sl2 Almost Overheating
1996 Saturn Sl2 Almost Overheating The Gauge Goes Close To 2/3 Not Quite Into Red. The Cooling Fan Turns On At That Point Bringing It...
Asked by
peakprocess
1996
SATURN SL2
VIEW MORE
SPONSORED LINKS
Coolant Leak Repair
Online car repair manuals
