Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Engine
Symptoms
Overheat
Engine overheating after leaking green liquid
2001 FORD EXPLORER
250,000 MILES
EBONY WILLIAMS
MEMBER
1 POST
My car leaked green fluid and now it overheats.
Jun 28, 2020 at 6:22 AM
Experienced Mechanic
Good evening,
The first thing to do is to check the coolant level. Most likely it is low and that is causing the overheating.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Then you need to pressure test the system to determine the leak and repair it.
https://www.2carpros.com/articles/radiator-pressure-test
Once you have the pressure test done, let me know the results so I can continue to help.
https://www.2carpros.com/articles/car-is-leaking-coolant
Jun 28, 2020 at 10:54 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
