Car over heated coolant and oil mixed sprayed over engine compartment
160,000 MILES • 3.5L • V6 • 4WD • AUTOMATIC
BFOX847
Jan 23, 2019 at 7:39 AM
Good evening
From your description, it sounds like you have a failed head gasket from overheating. That would require major engine work and possibly replacement engine depending on the damage done.
https://www.2carpros.com/articles/coolantantifreeze-in-the-engine-oil
Disassembling and inspecting is the only way to determine the amount of damage. In a lot of cases, it would be cheaper to just replace the engine itself.
Has anyone checked it for you?
Jan 23, 2019 at 9:19 AM
BFOX847
I have not had anyone check it as the repair is worth more than the car. If it was the water pump I checked that out and think I could fix it. How would I determine which bank has a failure? Pressure test? Compression test?
Jan 23, 2019 at 9:35 AM
No to a water pump.
You would need to do a leak down test in each cylinder. You would do both banks if you confirmed a failed head gasket. You never do just one side.
Jan 23, 2019 at 9:38 AM
