Car only accelerates when I remove transmission fuse
292,197 MILES • 3.5L • V6 • 4WD • AUTOMATIC
EMILYMICHEA
Please can you tell me and show me the images on how to fix my car? It only accelerates when I remove the transmission fuse. I’ve replaced the transmission, replaced throttle pedal, and even the ECU, but it’s still not working. Please, I really need your help with how to fix this problem. Thanks, if I get a quick reply.
Jul 6, 2022 at 7:09 PM
  • 55,845 POSTS
Thats a good one :0) let's run the codes to see what comes up, here is a guide to help please let me know what codes if any are in the system:
Jul 7, 2022 at 5:22 AM
EMILYMICHEA
I’m so excited about your reply, but still my engine and transmission show no fault only BCM bringing out U1000 my car only accelerates when I remove the transmission fuse and my A/T check says on but move without gear selection once I fix the fuse the A/T check goes off, but car won’t accelerate anymore. Please, I really need your help with this please. Thanks, if I get a quick reply.
Jul 8, 2022 at 7:05 PM
  • 55,845 POSTS
Did you have a service done to the transmission? If so, they need to use Nissan fluid only. Let's try a CAN scan to see what comes up, you can get a CAN scanner from Amazon for about $30.00. here is a video to show you how and a link to a scanner from Amazon:
https://youtu.be/u-4syLc-ifQ
Jul 9, 2022 at 5:33 AM
