You need to make sure battery has a full charge. Battery connections all clean and tight. Then check the charging system. If the battery is down, you can't do any testing. Take the battery off and get it charged.
I can help with owners manual, not sure about antitheft? If the link doesn't work just type it in the address line.
Click on the link, when the page comes up, click on pro center. Left column click on owners guide.
http://www.fordparts.com/
SPONSORED LINKS
Thursday, April 25th, 2013 AT 3:13 PM
