Crank no start
2000 VOLKSWAGEN CARAVELLE
269,870 MILES • 2.6L • 5 CYL • TURBO • 2WD • MANUAL
JAMESKEKANA
  • 6 POSTS
well my car is a Microbus 2.6i probably the problem with it is that it is not starting at all. Purchased a new module and the distributor is still in good condition. what could be the problem?
Mar 18, 2018 at 4:03 AM
  • 31,937 POSTS
Do you have any codes? not all codes will set a check light, do you have a good spark, injection pulse and fuel rail pressure, do you have the means to test for these items?
Mar 18, 2018 at 8:21 PM
JAMESKEKANA
  • 6 POSTS
I did the problem finding and probably found out that the fuel was not enough for car to start thanx.....
Mar 23, 2018 at 5:01 AM
  • 31,937 POSTS
Ok, good job thank you for using 2 car pros
Mar 23, 2018 at 5:58 AM
