I have replaced the fuel pump, EGR sensor, and checked the in dash fuses. I even tried to read the codes (nothing shows up) and the car still will not start. I have a spark from the plugs, not sure if the fuel pump relay is any good. For some reason, the throttle body is not getting any fuel, but you can smell the fuel build up. What could be the problem with this?
Nov 17, 2016 at 1:34 PM
