Radio not working and car not starting?
71,000 MILES • 2WD • AUTOMATIC
MRROYBH23
Jumped the car and it started and I then had the battery test and AutoZone said it was fine, but the display is black and radio not working. Try to start the car the next day and wouldn't start but had interior lights and headlights worked, jumped car again and it started. I went out 2 hours later and car wouldn't start again and still the display is black and the radio still not working.
Feb 21, 2023 at 11:22 AM
  • 55,746 POSTS
When the car was running did you have any warning lights on in the dash? I am wondering if the alternator is working correctly. Also, I would clean the connections at the battery.
This guide can help:
If the BCM is not shutting down, it will drain the battery as well, but I am wondering if the battery is still bad and just tested good as a false positive. Is the battery original? If so, I would replace it anyway because they don't last longer than 5 years. Here is a guide to help and instructions below for your car. On a side note, the radio and display will only work if there is at least 12 volts in the system. You can check this by using a voltmeter at the battery which should read around 12.4 volts.
Here is a guide to help with that as well:
Please go over these guides and get back to me. I also included how to check the electrical system for draw to help confirm the battery is the problem.
Feb 23, 2023 at 12:29 AM
