reprogram fob?
60,680 MILES • V6 • 4WD • AUTOMATIC
GALLARDOSTEPHY88
So I have the vehicle listed above that I just got a couple months ago through trade in. Everything was fine but recently my dashboard says no key detected. I couldn't get into my car one day and it wouldnt start so I changed the fob battery and Napa tested the battery stating it was at 67%. Now my car wont turn on at all anymore as a daily thing. The lights flash and horn keeps honking. The dashboard that previously light before does not anymore and stays black. I still can't get into the car and have to use the manual key to open the door. When the car finally does turn on the dash also says tire pressure monitor default. The fob remote start use to work to get the car on and just doesn't do anything now? What's going on? do I need to have my car re-synced? does it need a battery or is something else going on with the starter or fuses?
Aug 21, 2020 at 3:07 AM
  • 110,248 POSTS
What you are asking are very good questions. Since it eventually does start, it doesn't sound like a battery issue. I do have a specific question. You mentioned that it has a remote start. It is a factory installed system or is it something that was installed after the vehicle was built?
Also, if you have more than one key, does it happen with others as well?
Here is a link that explains in general how to reprogram a key fob. See if it is helpful.
https://www.2carpros.com/articles/how-to-re-program-a-key-remote-fob
Aug 21, 2020 at 6:10 AM
GALLARDOSTEPHY88
I believe that it was factory installed. I'm not too sure as I just got the vehicle 4 months ago. It has had 1 previous owner. I have changed the batteries in both fobs but car just doesn't turn on at all. The only way is to physically out key fob in the manual start slot and then my car registers trying to be turned on.
Aug 25, 2020 at 6:47 AM
  • 110,248 POSTS
At this point, based on the symptoms I feel the CAN bus system needs scanned. CAN stands for computer area network. All the computer modules are tied together via a few wires. By scanning the CAN system, it will pick up on any breakdowns in the system.
This is really the way of scanning in the future. Cars have so many modules/computers that if the manufacture was to separately wire each one, the car would weigh another thousand pounds. So, they use the CAN system
Here is a video that shows how it's done:
https://youtu.be/InIlnsjOVFA
Because of the complexity of what you are experiencing, I feel this is what needs done to limit possible causes. Otherwise, it will become a guessing game and a lot of money can be spent unnecessarily.
Let me know if this is something you can have done or if you have other questions.
Aug 25, 2020 at 1:13 PM
GALLARDOSTEPHY88
Yes I can do this. My husband at home has a scanner. I will reply back with any further concerns once I can ge this done. Thank you
Aug 26, 2020 at 2:51 AM
  • 110,248 POSTS
Sounds like a plan. When you find out, let me know. I'll watch for your reply.
Aug 26, 2020 at 7:34 AM
