Engine not starting
70,000 MILES • 2WD • AUTOMATIC
LISALAW1
Bought this car and it was running hot. I started checking the fuses, but I did not take the battery cable off first. So now the alarm system has my car to where it will not start.
Mar 11, 2022 at 4:00 PM
Good morning,
You can try a security reset procedure. I attached a guide for you below.
https://www.2carpros.com/articles/how-to-reset-a-security-system
As far as testing fuses, you never remove a battery cable for that. You test it with the key on with a test light. I attached another guide below.
https://www.2carpros.com/articles/car-not-running-advanced
Mar 11, 2022 at 9:18 PM
