car not starting
141,981 MILES • 4 CYL • 2WD
JEANNIE2009
my 2008 ford focus was starting and running fine but it is stuck in either 3rd or 4th gear it is a manual and also now it is turning over but it's not starting and I am about at my whits end on what else to try with it
Aug 13, 2025 at 1:17 PM
  • 55,748 POSTS
Hi Jennie,
So we only handle one problem per thread, we will fix the not starting problem on this thread. Please start a new thread for the "stuck in gear" issue. Can a ask if it will run on starting fluid, if so the fuel pump could have gone out or the inertia switch got tripped. I would check that first. Here is a video and the switch location so you can see if the it needs to be reset. Please what this video as well
https://www.youtube.com/watch?v=lXLJbuAZ4CE
Check out the images (below). Please upload pictures or videos in your response
Aug 14, 2025 at 2:09 AM
