Car not starting
12,000 MILES • 1.1L • MANUAL
ATO JNR
The car will not start except when i kick start it. The battery is fine, terminals are fine, two mechanics said they do not see anything.
Jan 16, 2017 at 5:18 PM
STEVE W.
  • 15,418 POSTS
Okay, so it will not start without a jump. Have the battery load tested. Then take your jumper cables and connect them to the battery and the ground to the engine block and positive to the same lug the battery connects on the starter. Will it start now? If so you have a bad connection. Cables and terminals like to corrode inside the cable insulation. They look good outside but are actually not any good.
Jan 16, 2017 at 6:09 PM
ATO JNR
Thank you Steve, it does start when i jump start it. The battery was tested and its all good.The problem only occurs when i start the car in the morning, lets say after 12 hours. During the day i have no problems at all.
Jan 17, 2017 at 5:28 PM
STEVE W.
  • 15,418 POSTS
So when you first try to start it what does it do? Loud click, chatter or nothing? If you turn the headlights on, do they come on? What do they do when you turn the key? I'm just trying to figure out if the battery is very low as a result of a parasitic draw (interior light staying on or module not shutting down)and requires a jump for that reason OR is it something like a high resistance in a starter relay or starter motor that the higher current of the second battery helps overcome.
Jan 17, 2017 at 6:36 PM
