Car not starting
177,492 MILES • 1.4L • MANUAL
ELVISSUN
The car started well yesterday in the morning and I arrived at work, when I knock off, the car could not start. When I turn the ignition once it switches on the dash board, battery, engine, oil, and hand brake. When I turn to start it does not start the engine. When I return the key, it does not switches off. It dimmed but when I depress the brake pedal. The battery, engine, oil, hand brake switches on even though the key is at off position.
What must I check?
Oct 3, 2018 at 6:06 PM
  • 55,746 POSTS
It sounds like the battery is low or the ignition switch needs to be replaced lets start with the battery load test this guide should help.
Cheers, Ken
Oct 6, 2018 at 8:39 AM
ELVISSUN
Hi Ken, thank you for a reply, we found the problem was the wiring, there were wires that were damaged by rats that supply power to alternator. The electrician fixed them. On Friday after work when I was driving home, I saw the speedometer dropped to zero while I am driving, the car could not stop, but when I get to the red robot the battery,engine,oil lights came on, but the car did not cut the power. It goes and it has done that three times until I get home. Is it a new problem or related to the fixed wires? Please advise. The Battery is months old.
Oct 8, 2018 at 12:10 AM
  • 55,746 POSTS
Yes, this could be I would re-check the wiring at the battery because it sounds like you have a bad connection/wiring still not giving power to part of the car.
Oct 8, 2018 at 3:24 AM
ELVISSUN
I will re-check the wiring , and update you.
Oct 8, 2018 at 5:12 PM
  • 55,746 POSTS
Please do.
Oct 9, 2018 at 3:53 AM
