Car not running the same after replacing the crankshaft position sensor
98,000 MILES • 3.0L • 6 CYL • RWD • AUTOMATIC
EVERYCAR_BIMMER
  • 5 POSTS
I have been having trouble on getting my car running back to normal. I recently replaced the crankshaft position sensor (P0335) thinking my car would run back to normal, but that was not the case. My car does not pick up as quickly and the rpm's go too high. The OBD scanner now reads codes P0370 and P1727 and gives me notices such as "Malfunction in Transmission," "Start-off assistance inactive," "DSC malfunction," "DBC malfunction," and the brake light is on yellow. What is causing this? what are possible solutions? I have hit a brick wall need help!
P.S my battery is brand new and fully tightened.
Jul 18, 2016 at 4:49 AM
  • 31,937 POSTS
This is a fautl with the sensor still, you may have a continuity problem between the sensor and the PCM, corroded terminals, loose pins in plugs or a high resistance in a wire, these need to be checked first.
Jul 22, 2016 at 7:32 PM
EVERYCAR_BIMMER
  • 5 POSTS
Thank you, your response is much appreciated.
Jul 24, 2016 at 10:26 AM
  • 31,937 POSTS
Ok let me know how you get on
Jul 24, 2016 at 12:06 PM
