Car not running right after main fuse replacement
327,000 MILES • 2.0L • V6 • TURBO • 4WD • MANUAL
HEMI POUTU
Hey guys, I have a little problem here that hopefully you guys can shed some light on. A couple days ago after I got home from driving my 7g 1995 Galant Sports GT TT . I had to help a mate start his truck so being a good go I let him use my battery. Now this where it get interesting once he finished with my battery he decided to put it back in my car and then bang he put the terminals on the wrong way. So yea had to buy a new 100a main fuse. Installed the main fuse, turn the key and yes the car started. But now is running rough as guts with bad acceleration cannot even feel the twin turbos spooling, plus on top of it the rev counter stopped working. Any ideas? Everything is stock and was working perfectly before that little main fuse mishap.
Nov 17, 2018 at 7:42 AM
Good evening.
Check all your fuses with a test light.
If they are ll good, there is a chance that voltage spike may have damaged your ECM. They cannot take those voltage spikes.
A lesson to learn, do not ever jump someone's battery or lend your out as you are the one stuck with the issues.
Nov 17, 2018 at 8:02 AM
