please can you tell me or show me the diagram to trace these trouble code P0600? i change the valve body and the car is not engaging gear.
Jul 7, 2019 at 2:04 AM
✓Experienced Mechanic
This codes is for the serial communication error. did you have this before and you replaced the valve body to fix it or did it show up after? If after let's check the electrical connector at the transmission to make sure it is plugged on all the way with no corrosion. Please let us know what you find. We are interested to see what it is.
