At sixty MPH engine begins to stall and loses power
113,000 MILES • V6 • 2WD • AUTOMATIC
ANNETTEDRENNAN1
Drives fine until about 60 miles than starts to stall and lose power won't go faster than 60. will gradually start decreasing then surges back up to 60 but will not go over that speed. goes fine driving in town.
Apr 10, 2020 at 9:09 PM
Good morning,
I would start by having the fuel pressure tested. You may have a weak fuel pump not supplying enough pressure to keep up the engine load.
https://www.2carpros.com/articles/engine-has-low-power-output
Another possibility is a clogged cat converter not allowing the engine to breathe correctly. You need to have the back pressure tested for excessive back pressure.
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
Apr 11, 2020 at 12:13 AM
