Car not cranking
8 MILES • 3 CYL • 2WD • MANUAL
MEBAN
It is a used car. The car will crank and start after the battery is charged and runs smoothly. But after it stopped on the run it will not crank and re-start. Have to be push started.
Nov 30, 2017 at 11:43 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
have the alternator and charging system tested. Unless you have an auto-parts store near you that you can make it to, you will probably have to remove the alternator and take it in for testing.
Dec 1, 2017 at 12:02 AM
