After a tire replacement to a bigger tire there are noises when trying to drive it and it will not move?
160,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
DANTE377
My car is making grinding noises and won't move I think it's because I had my tire changed and the tire was too big for my car. It was a 205 while the other tires were 175. I meant to get it changed but it was too late. I think it messed up the transmission.
Jul 25, 2022 at 3:40 AM
  • 55,500 POSTS
Are the rims the same as the old ones? or did you just change the tires? The transmission should be okay unless you forced it to drive as it was grinding. I would raise the car first the front and then the rear to see if the tires will roll. Here is a guide to help you
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Jul 25, 2022 at 10:22 AM
DANTE377
I drove it while it was grinding the tires roll
Jul 25, 2022 at 11:14 AM
  • 55,500 POSTS
So jacked up the tires roll with no noise? and then when you lower it they grind?
Jul 27, 2022 at 4:38 AM
