1994 Toyota Corolla alloy wheels
NESAN
  • 1994 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • 115,000 MILES
Hello, I have 14 inch stock wheels, I am planning to get alloy wheel. I am deciding between 15 and 16 inch. Which one will not affect my suspension. I want a smooth nice ride after wheel change.
For spare tire I am about to install a full size wheel. But this time a black standard rim instead of alloy wheel. Can I get 205 tires.
Tuesday, April 27th, 2010 AT 9:27 PM
MMPRINCE4000
  • 8,548 POSTS
If you go up one size in size you will have to go down in aspect ratio.
Wednesday, April 28th, 2010 AT 8:13 AM
ROLANDOWOLFE
You took precise decision of buying alloy wheels as they are more likely to resist against corrosion and rust. There are several dealers online for example http://wheels.net/wheels/toyota-rim.html and others to whom you can prefer. Now talking about shape and side then try to opt an identical peace as your original one, hence it will be more fruitful from the aspect of suspension.
Thursday, February 12th, 2015 AT 5:36 AM
