Car makes whizzing noise while trying to turn over but won't start
150,000 MILES
JACEYAM
2 weeks ago we changed the battery. We had to clean the throttle body afterward because it wouldn't idle. When it finally started it was making a metal grinding noise only while starting, but ran fine after that. Last week it started and made the noise, but the grinding continued the whole time and 2 blocks up the road the car died. It wouldn't start after that just made a whizzing/whining. Changed the starter and no change. Have no clue where to look from here.
Apr 20, 2013 at 2:15 AM
remove the starter motor again and check the flywheel teeth. the old starter may have damaged the flywheel
Apr 20, 2013 at 2:19 AM
JACEYAM
We looked before we put the new one in because we were concerned about that because of the grinding and it looked okay.
Apr 20, 2013 at 10:22 AM
