car loose power at 2500rpm
2003 CHRYSLER CONCORDE
78,000 MILES
AVTECH65
Hello. The car works exept when I step on the gas for more speed the car start to loose power at 2500rpm but this is what I have done so far. I replaced the TIMING CHAIN, CAM / CRANK SENSOR and the car still with the same problem PLEASE HELP! Thanks.
May 9, 2013 at 8:32 AM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
scan for codes and check fuel pressure first
May 9, 2013 at 12:47 PM
AVTECH65
The scanner is giving me code P0016,P0113.
May 9, 2013 at 5:19 PM
HMAC300
  • 48,601 POSTS
the first code mwhen fixed may take care of second one. but the first code is cam sensor/crank sensor misalignment. this could be sensors or phazers on the cam. so have apro check this. Or your cam could have jumped time which will bend your valves so have it checked soon
May 10, 2013 at 5:44 AM
AVTECH65
I just want to thank you for your time and assitence.
May 10, 2013 at 7:07 AM
