Car leans/swerves left
290,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
JGONZO2398
  • 374 POSTS
The car has been having this issue for quite awhile now, whenever you are driving the car it will lean/pull to the left. I took it to the alignment shop for an alignment, and they told me that all four inner and outer tie rods needed to be replaced. After those parts were replaced and the car received an alignment, the guy there told me that it still leaned to the left when he went for a test drive (he did not say the tie rods were the issue, just that they were bad), and that he thinks it is the lower control arm that is the issue, maybe that it is bent. I am not sure on how I feel about that, he said it may be bent due to an accident but the car has never been in an accident. Any thoughts?
May 12, 2018 at 7:26 AM
JGONZO2398
  • 374 POSTS
Here is a video I took under the two front wheels. I did not really see much other than a ripped boot on the upper ball joint but I do not think that would be causing the issue.
May 12, 2018 at 9:09 AM
JGONZO2398
  • 374 POSTS
And that ripped ball joint is on the right side.
May 12, 2018 at 9:10 AM
CARADIODOC
  • 34,414 POSTS
Hold on. Your mechanic obviously was never a student in caradiodoc's School of Automotive Knowledge and Repair Emporium! Ride height, which you observed is obviously not correct, is set by the springs. Tie rod ends only are part of the steering linkage for the two front wheels. They have absolutely nothing to do with ride height; only which way the wheels are steering.
A bent control arm does not affect ride height, at least not very much, unless it is bent into a pretzel. The forces holding up the front corner of the car start at the road surface, go up through the tire, the wheel, the wheel bearing, spindle, lower half of the strut body, the coil spring, the upper strut mount, then into the body. The coil spring pushes down on the spindle which is attached to the wheel and tire. There is a modified version of that design where the bottom of the strut is attached to and pushes down on the lower control arm, then the forces continue on through the lower ball joint, then into the spindle. Even with this design, ride height will change very little, certainly not enough to be noticed by eye, if the control arm is badly bent. If the arm is bent, the main problem will be it is no longer holding the bottom of the wheel in place, which means the alignment numbers on the computer screen will be incorrect. Where the tire makes contact with the road surface will be moved closer to the center of the car, or forward or backward a little.
Without getting into all kinds of exciting theory, ride height must be exactly as specified by the manufacturer to obtain best handling, tire wear, steering response, comfort, and shortest stopping distance. All tire and alignment shops have small books that list every car model and year, what the front and rear height specs are, and where to take those measurements. All newer alignment computers also have provisions for measuring ride height so it can be included on the printout for proof it is within specs, but some are only concerned that it be equal on both sides, not necessarily at specs. This was a real big deal in my Suspension and Alignment class, and it's a real big deal to experienced alignment specialists. Professionals will not even take your money for an alignment unless they are allowed to correct ride height first. It is also a real big issue with lawyers and insurance investigators. They love to find lowered cars and raised trucks on the other guy's car when it is their client that caused the crash. They will convince a jury that due to the altered ride height, you were less able to avoid the crash, and they will be right. That shifts some of the blame onto you even though it was their client who ran the red light.
Your mechanic was wrong on a number of issues. He apparently does not understand what affects ride height or how to correct it. He should never have attempted to align your car until ride height was fixed, and he should never have accepted the results that the car still leaned and still pulled after the service he charged you for. You would not pay for a haircut if your new, inexperienced barber did not know how to turn on an electric razor. You would not pay for a loaf of bread that was only half-baked. What did you get for your alignment dollars? You paid to have the lean and the pull corrected, and you still have a lean and a pull.
Besides bent parts, there are three main things to look for when ride height is not at specs. The most common cause by far is weak springs. This, and the fact that replacing them is a dangerous and time-consuming job, is why all the better aftermarket suspension parts manufacturers offer "quick struts" which are new struts with new springs and other hardware already installed. Replacing a pair of struts this way requires no special tools, and can be done in a matter of minutes. The car does still need to be aligned after that service. This type of strut is the best choice when the car already needs new struts, and it is old enough that the coil springs have sagged from age. Their higher cost is offset by the much shorter time required to do the work.
The second cause of low ride height is a broken coil spring. They all have a painted coating to prevent rust, but that flakes off over time. Most commonly they break near the lowest loop of the spring, I suspect because it sits on a plate welded to the strut body, and dirt, salt, and water collect there. Typically when it breaks there, you will not notice it until it shows up with the ride height measurements performed by your mechanic. You have to feel with your fingertips to find a break near the lower mounting plate, but do so very carefully. Any time a coil spring breaks, it does so by leaving very sharp points on the ends, and it is easy to cut your fingers.
Sometimes a spring will beak closer to its center, and it is not uncommon for a sharp end to puncture the sidewall of the tire. Even if that does not happen, you will feel the harsh bouncing over bumpy roads. There will not be any give, or movement, when you push down on the corner of the car because it is already sitting as low as it can go.
The least common cause is that lower plate on the strut body rusts away, then breaks loose. That plate is holding all the weight on that corner of the car, which can be well over 1,000 pounds. This failure can happen on any brand of car, but it seems to be more common on Hondas.
Here is two photos that show the front strut for your car. The green arrows are pointing to the lower end that slides into a pocket on the spindle, then it is clamped there. The red arrows are pointing to the steel plate that's welded to the strut body. This is where the coil spring sits, and where it pushes down to hold the car up.
The second photo is of the complete assembly you would get when you buy it with the new spring already installed. The blue arrow is pointing to the lowest loop on the spring where they commonly break. Sometimes you will hear a single, really loud bang when it breaks, but this part of the spring does not contribute very much to ride height, so after that one bang, you may never notice another problem until someone measures ride height. The more dangerous failure is when they break in the area of the orange arrow. This is where a sharp end can go through the tire. The purple arrow is pointing to the upper strut mount. It is a plate that holds the spring compressed when the assembly is removed from the car, and all the car's weight is supported by that mount. There is a bearing in it to allow the strut, wheel, and tire to rotate as an assembly when you turn the steering wheel. Sometimes those get dirt inside the bearings, or they just deteriorate, then they cause roughness, crunching noises, or banging/thumping/twanging noises as you turn the steering wheel. Those noises are almost always only heard when the car is standing still or moving very slowly, as in when backing out of a parking space. Road vibration at higher speeds helps those mounts rotate for steering, so you usually will not notice an issue at those times.
You need to have a second pair of eyes inspect your car. My concern is if the first mechanic did not understand the role of coil springs, what else does he not know how to inspect or what to look for? Are there any safety issues he overlooked. If this was at a one-man shop, or a small shop with just a few employees, look for a different one that specializes in tires and alignments. If you were at a larger shop where you speak with a service writer and not directly with the mechanic, explain that you did not get what you paid for, and the person overlooked the cause of the problem. Normally I would suggest a mechanic deserves the opportunity to check his work and correct his mistakes, but in this case, I would want a more-experienced person to work on my car. Had I done this kind of job at the dealership I worked for, I would be expected to find and solve the cause of the problem, then realign the car, all on my own time at no cost to the shop or to you for the work I had already done. You can be expected to pay for additional parts that were needed all along but you were not charged for yet, but the shop should cover the cost of the second alignment. The people at many shops will go beyond that and give you a discount on the additional labor charges as a way of apologizing that they did not do the job right the first time.
If you did not get a copy of the printout from the alignment computer, ask for one from the second alignment. I always put a copy on the front passenger seat with the items highlighted that I changed or adjusted. If you post those numbers in your reply, I can interpret them for you.
May 12, 2018 at 11:26 AM
STEVE W.
  • 15,415 POSTS
It really does not take much to bend some parts a hard pothole hit or tagging a curb could do it. However, another common reason for a pull would be a dragging brake or even more common a bad tire. To check for a bad tire just swap the front and rear tires and see if anything changes. To check for a dragging brake you can just go for a short drive and coast to a stop. Then go out and put the back of your hand down by the brake rotors on each corner. If the left side is hotter then the right you may have found the problem. Finding bent parts is a bit harder as you need to know what a good part looks like. For that a suspension shop could give you a second opinion.
May 12, 2018 at 11:38 AM
JIS001
  • 3,412 POSTS
Just to add to it. Have they crossed rotated the tires. A bad tire will cause a pull. That is the first thing I would do before putting on the alignment machine especially if the pull is on acceleration.
Weak shocks will cause some swaying as well and as CARADIODOC suggested a quick start would be of your best interest to have install and have the ride height and alignment rechecked.
May 12, 2018 at 4:02 PM
JGONZO2398
  • 374 POSTS
So all in all, the shocks and struts are your guys' best bet? Also, the tires were not crossed rotated and I also forgot to mention that the drivers side tire was replaced due to uneven wear, this was done the day that I brought the car for an alignment and they told me that the tie rods needed replacement, that tire was replaced.
May 16, 2018 at 1:53 PM
JGONZO2398
  • 374 POSTS
They replaced it and said that it was bad.
JIS001
  • 3,412 POSTS
Is there a differnce in tire tread depth from the new tire and the other? That can cause problems as well. Mismatched tires can cause some pulling and swaying also. So I would recommend you start with a cross rotate and see if it changes.
May 16, 2018 at 5:39 PM
JGONZO2398
  • 374 POSTS
I am assuming they are maybe so I will cross rotate them later today, thanks!
May 16, 2018 at 10:30 PM
CARADIODOC
  • 34,414 POSTS
Going back to your question about shock absorbers and struts, they do not have anything whatsoever to do with ride height. You can push or pull their shafts in and out by hand. Even those that are gas-charged just use that gas to reduce foaming on extended drives. You can still push them together by hand, so there is no way they are going to hold up the 1,000 pounds of weight on a front corner of the car.
You started out by saying the car is leaning to one side. That is a spring issue. Has ride height been measured? Has anyone checked for a broken spring?
If ride height is wrong, there is no way you will get acceptable tire life, and if ride height is uneven from left to right, there is no way you will ever get proper tire wear patterns, even if the mechanic is able to set "camber" to specs. Camber is the inward or outward tilt of the wheel on top as viewed from in front of the car. The alignment computer only shows those numbers for a car that is standing still on the hoist. Tire wear is affected more by the range of movements the wheels go through, and the changes in camber, as the car bounces up and down on the road.
Also, because the control arms go through arcs as they go up and down, it is important that the lower control arms start out by being perfectly parallel to the ground when the car is standing still. Then, as they go up and down, the lower ball joints move left and right very little. When a corner of the car is sagged, the control arm runs through a different arc that causes that lower ball joint to move left and right a lot as the car goes up and down. That scrubs the tread sideways across the road excessively and destroys tires very quickly.
May 17, 2018 at 5:15 AM
