Car leaking oil everywhere
215,000 MILES • 3.5L • V6 • 2WD
NICOLEATTEBERRY
I have a oil leak. And I can't tell where it's coming from. Also my overflow tank is bubbling but the car isn't over heating? And helpful things I can do? Also my entire engine moves when I put it into reverse, like it jumps almost. Not sure if it's the engine or transmission mount but I've replaced them both!
Dec 28, 2025 at 8:59 PM
KRAKENAUTO
  • 113 POSTS
Ok let's address these issues separately as they are not related.
1. Oil leak, there is a dye at the parts store you can add to your oil, it is a UV based dye you can see using a UV light.
2. Overflow tank bubbling, There could be air in the cooling system if it was recently serviced and not properly bled. But usually this indicates a blown head gasket many times as exhaust gas can enter into the cooling system causing the bubbling.
3. The engine moving when put into gear likely is a bad engine mount or mounts. You should be able to look while someone is putting it back and forth into gear and look to see which mount/mounts have bad bushings.
Dec 29, 2025 at 3:47 AM
